I need the plumbing for a 5m. Threaded pipe, some elbows, flexible hose ect.
Thanks Gene
Thanks Gene
GeneMiller said:Bob,
I figured that somebody would actually have the different plumbing for each of the blower sizes making it a little easier.
Gene
Larry Cobb said:Think about where the vacuum restrictions ARE :
(in order of importance)
1. Wand & tube (5' of 1 7/8" ID +bends)
2. Vac Hose f/TM to wand (100 feet min.2.5" w/foam)
3. Silencer (needs improvement)
4. Recovery Tank (if it has baffles)
5. Two Ft. of 2.5" ID plumbing from blower to recovery tank
GeneMiller said:Greenie,
I'm assuming that those are 2.5" connectors.
Yes, pretty obvious when you put them side by side with 2", kinda tells a story.
To go along with your theory why don't you make them straight instead of a 90.
Like this?
If you look close on the TNT pictured, you will see that exact straight 2.5 nipple coming out of the blower, some TM mfgs. think they cost a bit much, but I wanted it super thin walled for maximum airflow.
You are right about the hard 90 on my machine. I can see it would be a little restrictive. I going to change the connection at the tank so I can clean my filters easier. It's starting to hurt my wrists twisting that hose back to get at them. That hard 90 will be gone.
Great!
I'll put a relief valve on the tank.
If you do, just make damn sure your blower filter is super clean, every 6 mo. or so unscrew it and run the machine without it, IF you notice a dramatic Increase in vacuum sans filter, you know your "clean" filter isn't really clean...junk it, and get a new one, they can be deceptive.
It doesn't both me if you find fault with my machine. Sometimes engineers over do things with out thinking about it. While I'm welding the filter box is getting a little make over. Besides the 2" connections do you see an addition problem?
The bottom of your 3" Stack inside the box, look at how close it is to the bottom of the box, it's too close, cut a 45 deg angle in the pipe like the bottom of this custom piece:
Ron Werner said:Plus, why have a big ass blower on there if out of the gate its going to be restricted down to a blower a size smaller
I have a Roots 59,4' ports, it was plumbed 3" to the tank , 2" from the tank to the back of the truck. And I was wondering why I couldn't get decent vacuum at 150ft when other guys were claiming 400ft with a 4.7! Opened the Blower up more, to 4". changed the 2" to 3", added ft of 3" hose, made a world of difference.
Danny Strickland said:Greenie, i'll need some free trinkets for the unauthorized use of my CUSTOM 2.5" vac tank adapter.
please let me know when yore website is up so i can make my choices soon!!!
...why not make it so a blower has MORE then you can use, rather then only GIVING them so much??
If i regularly run 400' commercial runs, do i want a machine that has choked back blower plumbing, that MIGHT serve me....Or do i want a machine that i know with out a shadow that i could run 600'??
Thats just retarded thinking...
give them more....instead of less....period
Larry Cobb said:...why not make it so a blower has MORE then you can use, rather then only GIVING them so much??
If you want a machine that can run 600'...
you would have to start with:
1. A Blower that can run @ 17" hg. or higher, and has the heat-flow design to handle it
(new 4MR Sutorbilt)
2. A belt drive system to transfer peak HP from the engine to the blower.
3. A Recovery Tank without baffles
(which we have had for many years)
4. Better silencers
(which we have pioneered in low-restriction stainless steel )
