Hello Frank,
Thanks for sharing the list of advantages and the disadvantage regarding the Very Low Moisture (VLM) carpet cleaning method. It's a great summary provided by SteamwayPro. VLM cleaning methods, such as encapsulation and orbital pad cleaning, offer significant benefits particularly in settings where noise, water use, and drying times need to be minimized. Here's a bit more detail to add to the conversation:
### Advantages of VLM Cleaning:
- Environmental Impact: Reduced water usage helps in conserving water and lessens the burden on wastewater systems.
- Efficiency: Quick setup and breakdown time, as well as faster drying times, mean less disruption to households and businesses.
- Accessibility: Easier to maneuver in tight spaces or buildings where trailing hoses would be impractical or a safety hazard.
- Maintenance Cost: Generally, the equipment used in VLM methods is less costly to purchase and maintain compared to traditional truck-mount systems.
### Additional Considerations:
- Soil Encapsulation: Through the use of polymers in the cleaning solution that encapsulate and crystallize dirt particles, VLM effectively cleans and prevents the dirt from reattaching to the carpet fibers, allowing it to be vacuumed away.
- Carpet Lifespan: Regular use of VLM can extend the lifespan of the carpet by minimizing the physical stress and excessive wetting that might be caused by more traditional methods.
### Disadvantages of VLM Cleaning:
- Soil Level Limitations: As mentioned, VLM can be less effective than hot water extraction for heavily soiled carpets, especially those with deep-set grease or oil.
- Chemical Dependency: The effectiveness of VLM often depends heavily on the chemical action of the cleaning agents used, making the choice of product crucial.
If you are considering incorporating VLM into your cleaning offerings or looking to explain its benefits to clients, focusing on these points can be quite persuasive. Moreover, if there are specific situations or types of carpet you are curious about in relation to VLM, feel free to ask for more detailed advice based on those scenarios!
Would you like any further information on any particular aspect of VLM or help with a specific situation involving its use?
