What's up with lockdown?
Bryce C
DFW
Bryce
Sometimes my wand locks down on cut pile carpeting, but most of the time it doesn't. Just yesterday I was cleaning a cut pile carpet and the wand was locking down and very heavy to pull. I'm not sure what to do in those situations. The carpet had much more moisture left on it after my dry passes than usual.
I'm using a hole glide on an Evo 13" wand. It has some grooves going out to the side. They are worn down a bit, would carving them out deeper help prevent lockdown? Should I have a different glide to swap out in those situations? Would turning down the rpms on my machine to lower the vacuum power help prevent lockdown? I was running it at 1400 rpms with 100 feet of vacuum hose, which is at "medium" power in my CDS 4.8, maybe I should turn down the sauce on shorter hose runs.
I'd rather not wrestle against my wand and only end up with wetter carpet after my efforts. Any tips?
I"m really surprised to see a lockdown with that hole glide. Not normal for sure. But leave your settings on the machine as is. Can you remind us what the hg is set at on your machine?
Reactions: Bryce C
FredBoyle
Fred Boyle
Role
Cleaning Professional
Years of Experience
38
Basic airflow dynamics
The wand seal is most commonly created on wool and nylon
Higher piles typically grab the wand more than shorter plush piles
If it’s too intense , I’ve dropped the Butler into Mach 1 , it helps airflow relief
Full lockdown is t moving air , it’s Just breaking Your body
View attachment 133873View attachment 133874
Hey I got one just like that one....
What's it worth?
Bryce C
DFW
Bryce
Ok thanks. The hg is set at 13.5. Although I just pulled my seal-a-door out from behind the waste tank that day. Maybe I bumped and adjusted the release! I'll check the gauge next time I use the machine tomorrow, I only had a commercial vlm job today.
was it a plush?
I'd say it was a medium pile carpet.
Have you burped your gauge in a while?
Reactions: Bryce C
Bryce C
DFW
Bryce
Good tips, thanks!
What's it worth?
The Evo 13"? About $900 these days.
Bryce C
DFW
Bryce
I asked Google AI about wandseal or lockdown on wool and nylon fibers and it just grabbed a bunch of unhelpful random bits of unrelated info about cleaning wool and nylon carpet and acted like it answered my question, it has no idea what wandseal or lockdown in carpet cleaning is. This was its answer:
""Wandseal (or "lockdown") refers to a phenomenon where cleaning lines, streaks, or a "locked-in" appearance of dirt appears on a carpet, usually caused by improper wand technique, excessive moisture, or chemical residue during cleaning. It is more common on wool and nylon because of their specific fiber structures and sensitivity to moisture and chemicals
Key Reasons for Wandseal on Wool and Nylon:
Absorbency and Wicking (Wool): Wool is a natural fiber that is highly absorbent, meaning it holds on to moisture and cleaning solutions. Over-wetting during cleaning can cause water (and dissolved contaminants) to sink deep into the backing. As it dries, this water moves back up to the surface, bringing hidden dirt with it—a process known as "wicking" or "lockdown".
Sticky Residue Attraction (Nylon): Nylon is durable, but when cleaned, it can leave behind soapy, high-residue, or sticky shampoo residue if not rinsed properly. This sticky residue acts like a magnet for dirt, making the cleaned paths appear dark again within a few weeks.
Heat and Chemical Sensitivity (Both):
Wool should not be cleaned with high temperatures (over 160°F) or highly alkaline solutions, which can damage the fiber and cause browning or "lockdown" of contaminants.
Nylon often requires specialized, lower-pH cleaners (especially stain-resistant nylon) to avoid damaging the protective coating, which if done incorrectly, causes rapid re-soiling.
Wand Technique & Suction Issues: Inadequate extraction (poor suction) is a primary cause of wandseal, leaving too much moisture in the carpet. If a technician uses excessive water or improper angles, it leaves linear "water marks" (wand lines) once the carpet dries.
How to Prevent It
Thorough Extraction: Ensuring the carpet is not over-wet is crucial, especially for absorbent wool.
Rinse Thoroughly: Using a proper rinse agent to remove all detergent residue prevents sticky, re-soiling (lockdown).
Use Proper Tools: For these fibers, professional-grade tools with high suction are necessary to prevent leaving residual moisture and detergent.
Proper Drying: Utilizing high-speed air movers to dry the carpet quickly after cleaning prevents wicking""
AI is not helpful, knowing that is helpful. I am curious, why is this phenomenon more common on wool and nylon fibers?
