100% VLM ???
jessi
Jessi Lopez
What I like about the Mytee is that all the plumbing is 2 inch all the way from the vac motors to the hose barb. I have a few portables but the Mytee is my favorite. They have even more powerful machines but you need at least 1 20 amp circuit for them which is hard to find where I am.
Which mytee? Thinking about going w Vortex lite next
frank fratto
frank fratto
Come on down. I live on the Mendocino coast 9 miles from the town of Mendocino (Cabot cove in murder she wrote)a beautiful place to vacation . If i know your coming ill hold off cleaning the shop carpet till then and do the whole thing while your out playing tourist
It sound nice!!!
Been up and down the coast maybe 25 times?
I love that place!!!" California "
Mine is an old speedster. Originally designed for a single 20 amp cord. I've modified it into a 2 cord machine and added a more efficient pump. A Pumptec 217 permanent magnet DC pump. The newer Mytee speedsters and the Mytee Breeze are impressive. Don't bother with heat, it just robs you of vacuum power. They all need at least 1 20 amp circuit. Depending on where you live, they might be difficult to find. You might want to check out the Rotovac Monsoon. It is supposed to run on 2-15 amp circuits.
Reactions: jessi
SteamwayPro
George
On a average size room I use about 1 gallon of water using my WORX Sprayer
HWE uses 5-6-7 10 ??? times the amount of water VLM uses
So compared to VLM, HWE FLOODS the carpet with gallons of water
TM's don't come with 20 gallon dirty water tanks for a reason
They come with 70-110 gallon tanks because HWE uses and WASTES Huge amounts of water
LESS water MORE agitation !!!
Reactions: frank fratto
Your drunk. Mine has a 55 gallon waste tank and I could do multiple houses with it depending
on the size of the house. I don't need that large of tank, since don't do residential, and if I extract commercial, I use 2 truckmounts.
How much water does your washing machine use to clean your pads? Doesn't seem to be eco-friendly or vlm on the grand scheme of things.. Flooding your pads to get them clean when vlm is better........
Stop flooding your pads to clean them!!! Based on your logic, vlm should clean the pads... Maybe less water and more agitation will clean it..
I honestly try to see it from your point of view, but I can't get my head that far up my a$$ to see it..
frank fratto
frank fratto
Personally, I don't care how much water you use to clean carpet?
But the second you get the carpet pad wet, you become a
MUD MAKER!!!!
And that's when it becomes a PROBLEM???
And personally, I don't like to have problems.
And I know most you guys will say ,they don't have wick back problems?
But we all know the Truth???
It's the most un talkable subject???
So we don't talk about it???
Most carpet cleaners are [ MUD MAKERS ]--------------- NOT ALL???
2 very false accusations of flooding the carpet AND being a mud maker
Flooding: No way. Common sense says that when the carpet in real time with proper climate control is dry in 2-6 hours (depending on if you're in dry Nevada or humid Georgia), it's impossible for that carpet to be flooded. Exaggeration. I'm wasting my Time explaining this to the 2 simpletons.
Mud Maker??? really? Absolutely ridiculous. Mud is created by mixing water with dry dirt. Most of my jobs are vacuumed before any liquid touches the carpet. Then a 60hp gas engine tells this huge 56 blower to flush and extract out the carpet. And yes, I most of the time check my recovery water coming out the wand and notice is mostly clear before I move into another room. There's way less residue left behind than any bonnet can pull out.
You guys are goobers.
Reactions: Kenny Hayes
frank fratto
frank fratto
Goobers, Thanks for the compliment!!!
Most carpet that is more than 2 years old will have a thin layer of soil between
the backing and the top layer of the carpet pad,
if that becomes wet?
It becomes mud.
So most carpet cleaner will over wet the carpet, and it becomes MUD???
Sorry, it's just a fact???
Matt,
Would you like to talk about it??
Or do you deny this about our industry??
Let's talk this out??
We’ve been “talking it out” and you still deny it. Go get humbled and let Dwain show you the proper way to deliver a valued service.
frank fratto
frank fratto
Show us the mud and your source of this “fact”
Ok
I had employees , most of the time did a very good job.
I have friends in the industry and they have employees, and they do mostly a very good job.
our number one complaint about our employees is the call backs from over wetting carpet.
Me and my friends could honestly talk about this.
We all know it is a problem in our industry.
Because we all followed another company with in new customer's house
and they tell us it is a PROBLEM.
So some are, but not all [MUD MAKERS]
Seriously, obviously it takes a high psi to #overwet a carpet without getting it extracted properly. Again,
with a few more dry strokes, that's still hard to do. That being said, what psi and flow do you think it takes for that to occur? Also, goobers from Matt isn't necessarily an insult. Just sayn.
