Who can press new bearings on direct drive shaft?
KevinL
East Peoria Illinois
Kevin Leach
No suppliers nearby. WM pro 1200. Should I just take to regular mechanic or bearing shop or drive shaft specialty?
La La Land
Hold the shaft taper end down and bang on a 2x4 till the rear bearing comes out then place long metal tube in the other end and tap front bearing out......
THEN:
tap front bearing back in with some Locktight sleeve retainer on it......using a bad bearing!
THEN:make a "bearing retainer plate" bolting that on the clutch plate...
THEN
replace the shaft through the tube and onto the new bearing.....
THEN
go to the rear of shaft and set the new bearing in place...
THEN
tap it home using the BAD bearing the press it in...
THEN
remove the "bearing retainer plate" that kept the front bearing from popping out......
One other thing.... don't buy the cheap bearings.......the good ones cost about 50 bones apiece...if you don wanna DO THIS again...
BUY THEM!
is that clear?
  • Wow
Reactions: Bryce C
Benton KY USA
Wow Bob!!!
That was like having my father helping us out. He was a great tool&die and machine shop pro. I miss him, been gone six years now.
Thanks,
Lee
La La Land
jus remember...don't hit the shaft with a metal hammer....one good downward blow onto wood will usually pop the shaft right out!
KevinL
Kevin Leach
Thanks for the info Bob but I quit the mechanics job. I'm gonna let a grease monkey do it. I got Browning's. $60 each. Are they good?
La La Land
Are they TAPERED ROLLER BEARINGS...i hope not!
i've never used them...
actually the Jap bearings are better than the ones made in USA...
sealed double row...right?
KevinD
Binghamton,New York
Kevin Dumas
NACHI Bearings ?
Dwain Ray
Why are questions from 2009 poping up?is this part of the new and improved mb?this is the second time i almost spent time answering a 10+ year old question
Bryce C
DFW
Connecticut
Bryce
That's me Dwain-o! I was combing through old posts about driveshafts to learn stuff and things. I just learned that if I simply "like" a post or something similar it revives the whole thing. I think I've been unknowingly reviving ancient threads by doing this off and on for a while now. I thought my likes on ancient posts would be personal between me and the creator. But alas, we're all here and I'm a weirdo. I'm glad I'm secretly entertaining you guys.
Since y'all joined the discussion I do have some questions. What are signs of driveshaft problems one can watch out for before they begin? I read about someone's driveshaft busting in the engine compartment and causing a ton of engine damage!
Also when greasing these things, is it ok to pump it until it seeps through the seals?
Dwain Ray
All my experience is with sealed straight driveshafts. . As far as greasing goes i would pump grease same as i would on the vans driveshaft, till it seeps outa the seals unless told otherwise by hydramaster..
Reactions: Bryce C
La La Land
He’s a stubborn old fart
When did Mrs Vawter get on here ?
Bawb sits down to pee though..
Nate....to even admit that you visualized me sitting down to pee IS jus a bit strange! YES ....I did say you were a good looking guy.......but hey homE I don swing that way........
