- Feb 4, 2016
- 14,349
- Name
- Matt w.
1. Prespray: To spray whatever, with whatever is in your jug before you rinse, or agitate it
Actual definition when reading from left to right: To spray whatever, before you treat it with whatever you want. Idiot
2. Prescrub: To scrub before you rinse.
Actual definition when reading from left to right: To scrub before you scrub it again. Idiot
3. Helicoil: A heat exchanger that heats the water with heated antifreeze from the engine.
Actual definition: A Heli-Coil, also known as a Helical insert, is A threaded insert, also known as a threaded bushing or insert nut, is a fastener element that is inserted into an object to add a threaded hole. Idiot!
