- Oct 6, 2006
- 116,994
Are you suppose to dilute it?I hope not. SaigerCide is the best deodorizer on the market. The customers absolutely love it. It didn't take me long to blast through that 55 gallon drum I bought.
I normally dilute 4-8oz per gallon depending on how dirty the piss-hole is that I'm cleaning. If it's real bad I'll pour 4 cups in my acid rinse as well.Are you suppose to dilute it?
You'll find that the Matrix Breakdown formula is unique in that it can be rinsed with water vs most non-voltaile solvents like POGs requiring a detergent or voltaitle solvent to remove the residues POG will leave behind. Many have reached out over the past few weeks and have been pleased to hear the breakdown formula is sticking around!
thank you for posting this!You'll find that the Matrix Breakdown formula is unique in that it can be rinsed with water vs most non-voltaile solvents like POGs requiring a detergent or voltaitle solvent to remove the residues POG will leave behind. Many have reached out over the past few weeks and have been pleased to hear the breakdown formula is sticking around!
Blast P.O.G.
*Compare to Matrix Break Down P.O.G. For oil-based stains that refuse to budge, try MasterBlend Blast POG. Blast works quickly to remove grease, paint, tar, even lipstick, and can be rinsed out easily with water or MasterBlend Citrus-Sol MX Spotter. Treated areas dry fast to save you time Not...masterblend.net
that's CTIAre they the ones that made molecular modifier?
