Restaurant carpet
Folsom, California
Ray Vasquez
I have to clean one of my regulars and it’s a Mexican restaurant with tons of oil build up every time. I usually use Flex w/Citrus solve and my rotary 360, but the rotovac 360 is down so my question is…1- can I use my slow speed buffer on it? 2-if so what pad color do I use?…thanks for the feed back!
Prattville, Alabama
Green if you break it in on concrete first.
Here’s how:
Spray the concrete liberally with prespray
Run the green pad under your rotary on it for a minute
Now your green pad will work
If you didn’t break it in first, the pad would grip the carpet so hard your buffer would spin you through a wall
Folsom, California
Ray Vasquez
Here’s how:
Awesome! Thank you hogiowl!….that would be a sight to see huh, if I (250lb man) got tossed by a floor buffer😭
Bc
Or Saiger’s Code Red with a splash of Harvard’s Grease whatever … can’t remember.
Reactions: hogjowl
Montana
Swani
The 175 works fantastic on greasy commercial glue down, HOWEVER, get rid of the Flex. It’s crap!
Use Prochem Ultra PAC Extreme. Mix on the heavier side, let dwell for 10 minutes, hit with the 175, extract HOT.
I've tested a lot of different presprays side by side on greasy carpet and nothing out performes Ultra Pac Extreme.
SteamwayPro
USA
George
I'm VLM now but for the first 25 years I was HWE. I cleaned a lot of Diners and Chinese Restaurants. I used a 175 with a stiff brush every time. I had a Rotovac and T rex Jr but preferred the 175 and brush on Diners and Restaurants. The weight of a 175 on top of a stiff brush did a better job losing grease for wand extraction than just a rotary extractor.
Now that I'm VLM I don't do Restaurants or Diners
Darren Darner
Plover, WI
Darren Darner
Saiger red and the G Force Booster with a grey pad from Excellent supply under a 175.
Reactions: Kenny Hayes
Bc
Code red is a great product. I carry it on the truck daily, I use it daily. BUT, for this particular application, hands down, UPE, boosted if a guy feels like he needs the extra ‘oomf’.
I’m my experience, not necessary.
But hey, whatever blows your hair back…
Again, spray with a heavier concentrated UPE, dwell, scrub W/ 175, pad or brush, edge with an edging tool, extract with a good wand, and make sure the TM is set to HOT…
There isn’t much this combo won’t take care of….
Bc
skinning, skinning, not EATING!
I was having a whiskey with my neighbour a few weeks ago. He told me that a couple years ago, he had a bobcat tag, shot one, and he skinned and cut up for meat. His words ‘it’s one of the best meals in recent memory’.
No thanks, I’m not interested in eating Garfield….
Kitty steaks, roast, or burgers are not on my list of things to try…
Interesting. I think I need to have conversation with Sam…
First time I've ever tried it. It was on an office never professionally cleaned. They would have a staff member rent a machine to clean the carpets. The light blue carpets were completely black. When I was giving the estimate, I was sticking to the carpet. I was considering using Saiger's Code Red boosted with G-Force but stopped by Sam's first and he talked me into the Citra-zov powder. Was absolutely blown away at how well it worked. 5 Chinese ladies watching me cleaning, oohing and aahing over how well it came out.
Reactions: Sierra Clean Care
Citra-zov not Dis Zov All. That's a liquid citrus spotter.
Ever-Fresh
Idaho
Jeff Paton
Ever-Fresh
Idaho
Jeff Paton
People underestimate what pad cleaning can do in a grease-pit. Lots of pads!
This was from 2009-2010, and my third cleaning of a bar that specialized in homemade potato chips. The first time I cleaned you could not tell what color the carpet was from all the black grease. I used a strong encap solution in a sprayer and pre-sprayed ahead about 10 minutes ahead of where I was going. In the "day," there were not high Ph encap cleaners yet.
The bar was on the second floor attached to a parking garage. Only if I could get the closest parking space to the door could I run 200 feet of hose and use the truckmount, which only happened twice in the 21 times I cleaned it over 7 years.
How long did it take to clean that with pads and how many pads did you use?
