- Oct 22, 2012
- 28,101
- Name
- Ron Marriott
Can leave the fabric too wet.You just open up the relief valve.
Yes but if you set to tool down it doesn't keep the solution hotYou just open up the relief valve.
Sorry, not use to talking on forums yet i see now you weren't commenting to meNo it bypasses into the vacuum hose
Are you incapable of monitoring your work?Can leave the fabric too wet.
If you spend your time dry passing, what's the point? Use the right tool in the first place.Are you incapable of monitoring your work?
If you don’t spend time doing dry passes, you’re an embarrassment.If you spend your time dry passing, what's the point? Use the right tool in the first place.
When you're doing 2000 chairs, you gotta move.If you don’t spend time doing dry passes, you’re an embarrassment.
We weren’t talking about sprayers.
You’ll fit right in here.
still can't stand straight and i only did 350
I know , upholstery tool. But when i read 2000 chairs my ptsd kicked in i still can't stand straight and i only did 350
I have a reworked Pepsi container that's similar. Small portable air compressor that I can bring with me.If you're doing 2000 chairs you need one of these , i only did 350 chairs for a church with 2 of us 1 presprayed and brushed and the other cleaned this sprayer saved alot of time pumping up, you can't see it in the pictures but it has a 15' hose
View attachment 120133 View attachment 120134 View attachment 120135 View attachment 120136
Actually, I use it often for applying protector. Works great and not much to go wrong with it.another board DeJour item that went the way of the Dodo bird
(for good reason)
i use corny kegs for pet treatment most of the time I love themIf you're doing 2000 chairs you need one of these , i only did 350 chairs for a church with 2 of us 1 presprayed and brushed and the other cleaned this sprayer saved alot of time pumping up, you can't see it in the pictures but it has a 15' hose
For trash upholstery you’re better off with this uph tool from PMF!For trashed upholstery, you're better off with a PMF external jet and turn the pressure down. The internal jets don't have enough flow which is great on fine fabrics but is slow on trashed stuff.
NoFor trash upholstery you’re better off with this uph tool from PMF!
(Jim Pemberton do not read this keep scrolling)View attachment 120147
When you say internal jets your not speaking of a spray bar with ajustable flow sapphire or rotovac?For trashed upholstery, you're better off with a PMF external jet and turn the pressure down. The internal jets don't have enough flow which is great on fine fabrics but is slow on trashed stuff.
No, those aren't jets. The pmf is a proper jet which the vacuum modifies so that you only get a light spray coming out. You need to balance it.When you say internal jets your not speaking of a spray bar with ajustable flow sapphire or rotovac?
