- Oct 7, 2006
- 49,924
No he's got a giant Obo for it.
Foster made the comment that it will draw interest, for users who do a ton of tile, they'll be drawn to it.
But for every tool Tom sells Mike will sell 9 brush glides because it's way more affordable.
Let me know if Foster is right.
So what... no matter what you're going to have to run a flat mop over it.It seems to get the tile REALLY dry
When was Bob ever right?Foster made the comment that it will draw interest, for users who do a ton of tile, they'll be drawn to it.
X2So what... no matter what you're going to have to run a flat mop over it.
It takes about 20 seconds to switch glides.I’ve used this new tile wand that Tom invented and its amazing. Its not the same one that was being tested out a couple of years ago in Florida. Tom made some improvements that no one else has done or thought of. Its awesome.
A true professional uses a dedicated tool for the job. Not a Swiss army knife setup. Who really wants to be sliding glides off and on between jobs anyway? Unless you keep a brush glide on your wand all the time and only use it on tile. Then and only then you are a true professional.
so with that logic you should be using a vacuum for open areas and a separate vacuum for edges and uph.I’ve used this new tile wand that Tom invented and its amazing. Its not the same one that was being tested out a couple of years ago in Florida. Tom made some improvements that no one else has done or thought of. Its awesome.
Your judgment is clouded.so with that logic you should be using a vacuum for open areas and a separate vacuum for edges and uph.
and a motorcycle for day trips that would never see side bags for over nighters.
or a pan for eggs and a pan for steak and a pan for pork chops and a pan for grilled cheese and a pan for award wining caned chili
Comical.
And a tad bit harsh…Your judgment is clouded.
is it?Your judgment is clouded.
boring.into Corvettes and banjos.
Are u getting the tile wand????Whatever works for you. When on a job I like having the tool ready to go. I don’t like having to change out heads on equipment or fittings on brass to make something work. Now if you are a part time cleaner like the Metermaid, then go for it.
And Mikey. You know in 10 years you’re going to make a completely different argument. I’ll be pushing glides and GVF and you’ll be into Corvettes and banjos.
Cool.
