- Oct 6, 2006
- 116,673
Not had to, enjoyed doing it.Like you ever had to
SMH
It looks hideous,Your lying if you say you don't have them.
Exhaustion plus Knots, kinks, dog shit on your pressure or vac hose, need I say more?
Well, even VLM'rs can have one...
See it?View attachment 113284
Yeah, no.I see the fittings starting to rust.
I had a similar issue with my Orbot when I changed out the pump. Because I could not find the same diameter hose locally, I ended up switching from the sharkbite fittings to compression fittings. I wish I could have used the same hardware, but what you gonna do.The problem is some idiot went and bought quarter inch inner diameter hose at Ace hardware. That is probably two millimeters off from what in needs to be in those snake bite fittings and never tested before he got to this job and was shooting saiger encap all over the goddamn place..
You can clearly see the undersized hose in that picture
Bronze no doubt..Is that some sort of putty or rust or just a brown clip?
Blue.My vac hose broke. I need new one. What kind do you prefer?
With all that bluish carpet?Blue.
hey remember that job you went with to me and the lady called the wrong company, then we went down to Coleville to do a unit?
the new owner of that house had me over to do an estimate.
Just cut the broken piece off and reattach the cuff.My vac hose broke. I need new one. What kind do you prefer?
Its somewhere on it. The massive vacuum leak occured 2 days ago and I cant find it . It's a old hose anyways, so I getting new 50ft todayJust cut the broken piece off and reattach the cuff.
Or, just buy a new hose
