- Feb 4, 2016
- 14,574
- Name
- Matt w.
I have used one.Have you ever used a devastator? I have...I'm a believer...all your questions has already been answered and implemented...
I have used one.
I say mikey, Marty and larry are idiots of the day
Call back city....they never listen.Seems your little extenders are streaking the carpet.
I’m sure that was a reason,I've never used jet extenders.
I thought they were about trying to compensate for TM's that didnt produce enough heat?
Looks good...other than the jet streaks.
No bridge marks!
I noticed that too. I don't know why it showed the marks on the first job and not the second. I increased the water pressure on the second job to try to cause distortion and it didn't happen. I'll leave it at the set psi of 600today and see if it gives the same result. I like the new glide much better than the one I bought a couple years agoNo bridge marks!
Feel the love...I noticed that too. I don't know why it showed the marks on the first job and not the second. I increased the water pressure on the second job to try to cause distortion and it didn't happen. I'll leave it at the set psi of 600today and see if it gives the same result. I like the new glide much better than the one I bought a couple years ago
Yes, I had to increase the angle jets from 6, 80 degree jets to 4, 110 jets and 2, 95 jetsSo if you use extenders do you then have to install wider angle jets or does it not make any difference?
I must commend you on your ass-iness tonight. You're really out doing yourself.Of course it makes a difference
But don’t confuse him any further
Naww that's no way to deal with it. You'll end up constipated and angry like someone I won't mention.I'm in a pissy mood also, but I'm trying not to take it out on you guys.
He never disappoints.I must commend you on your ass-iness tonight. You're really out doing yourself.![]()
Or ALWAYS disappoints depending on your perspective.He never disappoints.
I bet you hear that a lot Richard.Or ALWAYS disappoints.![]()
☹I bet you hear that a lot Richard.
