When it comes to wands, what manufacture is the toughest to make glides for?
what manufacture is the toughest to make glides for​
I'm going to "guess" the non-cast head models?
'cause I don't figure the +/- tolerances of assembling/welding stamped sheet metal heads are all that tight
Reactions: ImperialCC
Very true
Carpet CLEANING forum
Not Carpet manufacture forum
Maybe you should start another section and invite only the soap salesmen to that group.
Reactions: Numero Uno
Spanky forget to set a parking brake or did he rifle through a teen age girls' nightstand?
He's doing good. The workload is killing us. Gonna need to pull back a bit. I feel my sanity fading. My next day off is Dec 18th. The Promaster needs to go in for repair work. Losing antifreeze and dumping tranny fluid. My helper averaged $38 an hour last week with performance bonuses.
is there a transmission cooler on your van?
I don’t think so. But i have a check engine light on and a PO0740 code showing which means Torque Converter open circuit.
The FIAT name was a warning sign
Money pits like radars used car lot MB, Porsches and BMW
I'll probably end up getting promaster. Amazon been buying up the 3500 transit
