- Oct 6, 2006
- 117,375
Switched from Mobile1 for the 370..
Some oil ports in some engines need that thinner oil to lube you're camshaft properly.why didn't you go with 10-40wt?
a carpet wagon is never under 32 degrees temp.
and runs in an environment much hotter than that
I thought the purpose of high mileage motor oil was to keep the gaskets more soft to prevent leaksNot sure if high mileage oil would help a Kohler. I think high mileage is for the internals where a Kohler just leaks out the gaskets especially the valve covers.
Looks like it has additives to condition internal as well as external seals to help with oil consumption along with extra detergents for sludge build up.I thought the purpose of high mileage motor oil was to keep the gaskets more soft to prevent leaks
I don't know, Jimmy studies this stuff pretty well. I'd go with Jimmy, he's impartial.I just go with what the engine manufacturer suggests
I figure they’re smarter than jimmy
That's why I told him to stick with the Kohler oil.I just go with what the engine manufacturer suggests
