- Oct 6, 2006
- 117,344
OP scrub and Zipper SS rinse.
Nowhere near heavy enoughSeems like a waste of pads. Maybe a carpet brush for a CRB instead.
The car you should be saving forWhat's a CRV?
When you can knock on carpet like wood, a CRB does NOTHING....
I know this, cause I clean 2 different pubs...
One is a blue collar, logging, hillbilly bar.... I used my 175 with a red pad to cut through the gunk, and blasted it @ 750PSI, and Max heat for rinse...
When I presprayed, I may as well have been spraying a wood floor...
It was bouncing up, and sitting on top....
I could see my OP with a Gorilla pad being very effective.... only difference? I’d be tank feeding a nuclear prespray...
Interesting. I’ll have to try that...You can run whatever pH 14 prespray you want to run through there but it won't "release" the soil as quickly as a neutral pH end cap will for whatever ungodly reason...
This statement is false. I use a CRB on a fairly regular basis, and not only does it help to remove ground in soil, it lifts the fibres up, and scrubs the prespray in. The end result is FAR superior to using a grandi groomer, and wand...oh, and CRB's ain't squat for scrubbing soil off carpet.
One step above a grande grOOmer is all.
I agree. Those nuclear presprays are not where it’s at anymore.You can run whatever pH 14 prespray you want to run through there but it won't "release" the soil as quickly as a neutral pH end cap will for whatever ungodly reason...
A wheels up posThis statement is false. I use a CRB on a fairly regular basis, and not only does it help to remove ground in soil, it lifts the fibres up, and scrubs the prespray in. The end result is FAR superior to using a grandi groomer, and wand...
This machine, like all others, has its place in our industry...
Have you owned a CRB Larry?
Yea they are easy. Great machine to add to the toolbox.semantics
it's still a rotoscrub, just easier and more idiot proof than a rotary or rotary with the shakes*
*other than demos, I've never run a wheels down Opie ...so I really don't know if it's as idiot proof and easy as a 'mex
Easiersemantics
Eggsactlycotton, a pad did a great job ....for 1 sq yrd
Difficult yes. But it can be done with my 175 Husky''s.
John G would be really proud of Mikey and Sager comments in the video and this thread.... Kinda different tune from five years ago...
