Mike...
Headed out to play in the desert now.
Trails should be empty
Google up Anaconda Mine, Weed NV if i dont come back
FB7777
I’m talking about the outside Jets are too far to the outside, not sure how you would adjust that without replacing the manifolds.
How bad does it overspray on the sides ?
is it a 95 or 110 angle jet?
you could adjust it by turning the jet a little , wouldn’t strike the carpet straight but wouldn’t overspray
That's exactly what I do. 95's on the ends and 110's in the middle. It cleans right up to the edge without any over spray. Usually around 500 psi and 6 flow. The sheer angle of the jets is adjusted to hit just before the glide. The sapphire may be better, who knows, (besides Mikey) but I don't like the 2 inch flare in the 1.5 inch tube. You end up playing with your hose cuffs more.
Yukon, Oklahoma
Just like the marvelous Bane wands🥴
Ron K
Compression Socks and Legs up the wall Yoga.
Where do you get your socks from?
can never get them long enough.
Meter Maid
The Undetective
Dayton,Ohio
My buddy took a pic of his house and then photoshopped something into the pic for his daughter.
Look above the pine tree on the left side of the house. You’ll have to zoom.
Reactions: FB19087
