- Oct 6, 2006
- 117,350
Casey Kasem's old house..
Its the drivewayYou parked on a deck of a dead guy, your future is bright.
Its the driveway
5..how many floors down does it go?
You should try an Oreck. I am amazed at how easy it is to do stairs.5..
they just bought the house recently and hadn't had the carpets cleaned except for Mr trying to do it himself with a rental..
They were convinced that I would be able to run the vacuum and pressure hose down the elevator shaft and some I'll be able to go up and down the staircases 5,000 times to do everything else...
Yeah. No.View attachment 103539
Phoenix wouldn't fit through with the wheels down..
Luckily she runs upside down where the wheels are barely got through..
Only one carpeted staircase
Spray bottle and a Glad Pad ala' Chem Dry
Do they make a square version?You should try an Oreck. I am amazed at how easy it is to do stairs.
Told ya....You should try an Oreck. I am amazed at how easy it is to do stairs.
?, please explain...Pad Son is worth the money for stairs. Spent years trying different tools and finally bought a Pad Son and it does a great job.
John Guerkink used to sell a hand polisher called the Pad Son. They sold pads to fit it too. It was built well and would do a great job on steps or just as a spotting tool.?, please explain...
I'm going to have to get something so far the two staircases I've done I've managed to be sneaky about and nobody's ever bothered to ask how the hell I held the Phoenix on the the risers..Pad Son is worth the money for stairs. Spent years trying different tools and finally bought a Pad Son and it does a great job.
Well now. I don’t feel so bad about my warranty fetish.I'm going to have to get something so far the two staircases I've done I've managed to be sneaky about and nobody's ever bothered to ask how the hell I held the Phoenix on the the risers..
Lol
Check them about one. If you don't like auction it off. I think you'd like it.I'm going to have to get something so far the two staircases I've done I've managed to be sneaky about and nobody's ever bothered to ask how the hell I held the Phoenix on the the risers..
Lol
Kills your back bending over. The Oreck, you can start at the top and work your way down. Scrubs the bull nose, then the tread. Once you get the hang of it, you can zip right through them. I have about 150 stairs coming up next week. That's what I'll use.John Guerkink used to sell a hand polisher called the Pad Son. They sold pads to fit it too. It was built well and would do a great job on steps or just as a spotting tool.
There is a square doodle bug that I think is made by square scrub. Pricey though.Do they make a square version?
Never tried one but sounds awkward or does the handle slip down?Kills your back bending over. The Oreck, you can start at the top and work your way down. Scrubs the bull nose, then the tread. Once you get the hang of it, you can zip right through them. I have about 150 stairs coming up next week. That's what I'll use.
No, I watched a video of a guy doing it and copied him. You kick the machine over the bullnose and just swing it back and forth. A couple of swipes is all you need. Best tool for scrubbing the bull nose I have ever used. If the bullnose protrudes over the riser, it make the riser a little difficult but the risers aren't usually dirty anyway. I turn the machine off before plopping it down to the next stair or eventually the pad will come off. You stand upright and just let the machine do the work. I spray one floor at a time. I will see if I can do a video next week.Never tried one but sounds awkward or does the handle slip down?
As far as killing your back, I think it's much easier and faster than HWE stairs.
Go to Walmart and get one there. They have terry pads too. $500 for a random orbit car polisher is a bit much.John Guerkink used to sell a hand polisher called the Pad Son. They sold pads to fit it too. It was built well and would do a great job on steps or just as a spotting tool.
Willy I did that and those are fine for buffing a van after waxing but don't have a powerful enough motor for carpet. The one John sold his heavy duty commercial. Metal not plastic, not sure of its original use.Go to Walmart and get one there. They have terry pads too. $500 for a random orbit car polisher is a bit much.
This will do the same thing for $400 less. My favourite
PolishMaster Professional Random Orbit Polisher - Bed Bath & Beyond - 1422814
Shop for PolishMaster Professional Random Orbit Polisher. Free Shipping on Everything* at Bed Bath & Beyond - Your Online Home Improvement Shop! - 1422814www.overstock.com
trinityopsystems.com
I take it used the small one?Thanks Fred!
5..
They were convinced that I would be able to run the vacuum and pressure hose down the elevator shaft and some how I'd be able to go up and down the staircases 5,000 times to do everything else...
