Does Very Low Moisture Carpet Cleaning actually remove soil?
Cleaning Professional
When I do VLM I take a large mop bucket. Dunking and wringing the pads yields such dark slops that I have to change the water every couple of pads. It also allows me to carry on with the same pads on a large job.
I’m surprised your pads did not give up a LOT more soil.
Give him a few min, being inebriated has that effect.
When I dump my tm or portable, the water is much darker and thicker.
I'll never accept that reasoning. Especially while I still owe a chunk of money on my truckmount. Flushing it is the only way, unless there's no access to run a hose. Then I'll buff it and make some fancy looking foam
If you use a portable once in a while, you'll get up close and personal with what dirty water looks and smells like.
I was a Miller's hack for a year or more, don't talk to me about portables like I'm a Kirby salesman...
How many TM jobs do we do where the translucency of the waste water is a.... disappointment?
Reactions: Trip Moses
Yes, it does. The magic polymers and encapsulant "Jimmy crystals" encase the dirt binaries. Erstwhile the magic oscillations of the vibrating pad engender the adamantine encapsulants and incrementally advance into the reverberating pad. Thus relinquishing a breadth of cleaner nadir surface behind. The effectuated goal will culminate into a mirthful patron.
- @Jim Pemberton on Damon's abacus
You ought to see the dirty water in my plexiglass pump out when in doing a large building. It turns black in 5 minutes and just get thicker as the day goes on. One of my best marketing tools as everyone who sees it is mesmerized by how dirty it is.
sassyotto
Paul
yes, all methods (even HOST) will remove soil from carpet. It would be neat to be able to determine what percentage each one removes tho.
