Titan/Thermalwave ECU
Glynn
I remember people getting an engine ECU cable extension cable so that they could move the ECU away from the engine on Titan 875 & Thermalwave's.
Anyone know where to get one and any other information about them ?
I don't really know anything but see where @Jim Martin and others moved it (depending on engine). It is also mentioned that sapphire had or could get an extension.
and it looks as though @GeneMiller extended it on his own
Which engine/injection system are we talking about? Zenith?
Its the GM 1.6 Vortec.
that's the one I have and there should be enough cable already attached to it....it is mounted under the engine in the front...and on mine the cable should be wire tied in a bundle in front of it...take it out the side left side of the machine where it can stay cooler.....
Reactions: FB19087
But where do you get the cable ?
you should not have to get any cable for the vortex model...there should be more than enough already attached to it to get it outside the engine compartment..........
What if he needed a new one to replace a broken old one?
Probably sapphire????
  • Wow
