I need me suds.
I hate using presprays and encaps that don't foam up or at least turn white upon impact.
Procyon users know what I'm talking about.
Heck, rinses to for that matter.
Steve Lawrence
Mike, do you have the hydro force blues? Unable to tell when it's not working and you just soaked down 3 bedrooms and a hall with water only. Guess that's why we switched to a battery sprayer to put down the proper ratio of chem. (BTW we would like to use Procyon but salt based products like that are brutal to CRB's which we use constantly.)
Buy a von Schrader machine. You'll be happy as a pig in shit.
Reactions: Trip Moses
It's been quite a few years since a HF has failed me
Put some of that scampoo in your HF and hook it up to your TM. Next time you do a large commercial big room hose it out and bonnet clean it in minutes
Or add a foaming agent in it. Make sure you record it. Should be fun to watch your miscalculation...
When you use a hydro-force every day, you know quickly when it's not working. Hydro-force is the absolutely fastest way to get your prespray down. I use procyon every day and it hasn't buggered up my crb yet. Then again, I wash my crb every day as well.
I call BS.
70% of the carpet you and I clean would come out fine with just water as a pre-lube
Reactions: Hack Attack
Comes out better with a proper prespray. Then you have to worry about the other 30%.
I call BS.
My HF blocked up last week and like a muppet didn't realise till I'd "presprayed" 2 areas...
Extracted it like the hack I am with more of the acid rinse that was already down, looked good 👍
Reactions: Mike Pailliotet
Mike, do you have the hydro force blues? Unable to tell when it's not working and you just soaked down 3 bedrooms and a hall with water only. Guess that's why we switched to a battery sprayer to put down the proper ratio of chem. .......
Yep.
Having employees is a bitch, isn't it?
  1. If your pre-spray contains any chem that has a scent (delimo, etc.), they should be able to smell it when they spray. Brain/smell switch-----on!
  2. Do mention in the employee book (page 1012-b) to make a mental note- as to at what level is the HF when they start and when they finish.
  3. Signing that they "read and understood" the book is lovely, following directions is even lovelier.
  4. A good rinse will always save one's ass.
  5. Just like Mike, clean only clean carpets.
Not that you don't know but.....just do what works best for your company, Steve. Hell, it worked well for you so far. :winky:
Tom Forsythe
Not all soap free products will corrode metal parts. We added a corrosion inhibitor to Clean Free since it is used both as a pre-spray and a rinse. Any product used as a rinse should have a corrosion inhibitor added. We add 3 corrosion inhibitors (2 of them have cleaning functions as well) to our End Zone and Fab Set.
When I worked maintenance at a milk plant we used a detergent metered into water jets as a lubricant on the chain drive that moved cases thru the plant.
BASF had a continuity meter on the jets connected to an alarm if the soap was not sufficient in the output.
