Deke Hatley
- May 1, 2019
- 176
- Name
- Deke Hatley
What is your preferred All Fiber Rinse?
What do you mean by All Fiber Rinse?What is your preferred All Fiber Rinse?
An acid low ph rinse to use after cleaning with a high ph type pre spray. Looking to try a new one preferrably with a pleasant scent.What do you mean by All Fiber Rinse?
I never use acid rinses unless I am trying to correct a problem.An acid low ph rinse to use after cleaning with a high ph type pre spray. Looking to try a new one preferrably with a pleasant scent.
Hmm, I've always been under the impression that it's kinda standard anytime you do a really nasty one and have to use a really heavy duty high ph prespray. That it prevents re-soiling, brown out, and leaves the carpet nice and soft. Also enjoy the smell of most of them I've tried. They're pretty cheap so I've always used one.I never use acid rinses unless I am trying to correct a problem.
What brand to you run?rinses are cheap so yeah I use them
I run an acid on probably 80% my jobs but on the nastys I tend to run an alkaline not acid for extra cleaning boost
They do nothing to prevent resoiling. If you dry the carpet down it won't brown out. Your high pH prespray is neutralized by the acidic nature of the soil you are removing. I use a moderate ph alkaline rinse like Procyon. Gives more cleaning power and removes more prespray and soil, leaving the carpet cleaner in my opinion. I have tested the pH of the carpet after cleaning with a pH indicator pen and it is always close to neutral. I use acid rinses to help correct browning from water damage or remove final traces of urine in carpets.Hmm, I've always been under the impression that it's kinda standard anytime you do a really nasty one and have to use a really heavy duty high ph prespray. That it prevents re-soiling, brown out, and leaves the carpet nice and soft. Also enjoy the smell of most of them I've tried. They're pretty cheap so I've always used one.
brands you've never heard ofWhat brand to you run?
No real evidence to show any rinse agents work
Or don’t work
Spend your money with whoever you like
