If any are interested
Wade Moore
Harrington
Wade Moore
This is a break room I did yesterday that I do 3 times a year. The equipment I use is a kiavac 1750, 17” floor machine with conditioning pads, and a flat mop. I spray the floor with water and top scrub the poor layers of finish down to a good layer. To apply the finish I use a microfiber flat mop. I pour finish straight from the bottle and spread. No mop and bucket. With high and low spots it will look splotchy but will not be noticeable after the finish is applied. Sometimes it might take 2 maybe 3 coats of finish. It depends on how much you have to remove. When I’m done applying finish I keep the flat mop in a trash bag to keep it fresh. This break room is 1340 sq ft @ .60 sq ft. So one coat is all I do. It takes me about 5 hrs. with moving tables and all. When scrubbing the floor it is more like a wet sanding than making a slurry when using stripper solution. You don’t want it to dry but if it does it dries to a powdery film which can be wiped off. You cannot do that when using a stripper solution you would have to re-apply.
ED4DBF37-B288-4E62-BFCC-FF1D41B75BF8.jpeg 08893A41-ABBF-4155-8602-23EBC80B3DA6.jpeg EFBC47DB-B8C7-4A2E-A2CE-AC3C8F54A956.jpeg A0279D6C-48AB-4EB7-A846-8CF89B72F00D.jpeg 107D96C3-9C4E-4849-B448-8A25D1953C55.jpeg 1E397707-BDE2-4CD3-AC6B-18FBABDBF3CF.jpeg ED9331F3-3353-4D78-A83F-9C469761D3FE.jpeg 0E9C2877-319F-403A-B076-6A9180E914B4.jpeg 6E0C3504-2E35-49C7-ADAD-E09F593D973D.jpeg
  • EE44D40D-1931-4F61-8103-44A1C84F9AAA.MOV
    27 MB
  • 604AEF5A-A958-4128-AC30-070A8121A274.MOV
    31.7 MB
  • 53437768-C906-4DCE-8A53-25E63EF921DA.MOV
    20.3 MB
  • 41B28501-8694-4C32-B305-27C76458935C.MOV
    29.4 MB
FB7777
AAAAH
JANITOR PORN
I'd rather lose $1000 than have to go out an earn it working with wax and stripper
If you have to explain a joke, its no longer funny. Must be some short guys on this board cause these fine jokes just go right over your head.
FB7777
perhaps an explanation dilutes the impact of the “humor”
Kindly explain anyways
