Phewy or wowee?
Is Jimmy back?
Salt Lake City, UT
Eric
I've used a gallon or two, both VLM and HWE, but primarily HWE. I'm a part time cleaner doing 4-5 jobs a week so I'm no expert but I've used most of the popular presprays out there. Carpet Details works as good as anything and I feel like I use less spotter when I use it too. My uncle has been using it for years and won't use anything else.
Wand Slinger
Charleston
Christopher Paulhamus
I've used a gallon or two, both VLM and HWE, but primarily HWE. I'm a part time cleaner doing 4-5 jobs a week so I'm no expert but I've used most of the popular presprays out there. Carpet Details works as good as anything and I feel like I use less spotter when I use it too. My uncle had been using it for years and won't use anything else.
Do you have a MSDS sheet on it?
Ya but is says it’s encap is a vacuum away like crystallization in formula 90. Not like a polymer! Probably green surfactant makes a ton of claims for 8.2 ph product.
On product to rule them all!
Sounds like
Mikes magic potion!
using the term "encapsulation" when there are no polymers in the recipe is
disingenuous....
Although I don't consider it a true encapsulant because of that, the theory is because any residue left behind dries to a crystal, the soil is also crystalized and can be vacuumed away.
GeeeAus
Whyalla
Grant Baverstock
It’s just the same as every other soap free product.
