Best gum remover
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
Gel Break, volatile solvent in a gel form that won't go down to the backing. Stays put even better than other gels.
Score marks on the gum, then the Gel Break and let it sit a minute or two.
Grand Rapids, MN
encapman
St Petersburg, FL
Rick Gelinas
Having cleaned literally millions of square feet of carpet though the years - the simplest and most effective approach we found is a 2 step method...
1. GUM SPRAY: Freeze the spot with Gum Freeze Spray. Using a dull knife/scraper - chip off the frozen gum wad that's on the surface of the carpet.
2. SOLVENT GEL: Next apply a dab of a good solvent gel. Wipe away any sticky residue remaining on the fiber.
This process will normally take less than a minute for each piece of gum.
Reactions: Walrus Gumboot
Ron K
Take and your glide off and chop strokes get as much heat on it back and forth
a few second like that usually takes care of it VDS for the residue.
I normally use whatever gel solvent I have with me. Right now I’m using Harvard’s gelzov stuff. Last time it was HydraMaster cleanmaster OJ
Get it malleable with the hot water from your wand, agitate it, apply the gel, agitate, rinse again.
I’m bored. I just got home from The Cracker Barrel and I regret eating there
Is that where the Georgia crackers go to eat?
