Acp
- May 15, 2017
- 1,093
- Name
- Bjorn Marshall
nope lol, but its a #3 lg so its always on highest setting.No temp guage?
the temp guage or the filter? temp guage would be cheap and easy if u needed one.. the filter I think I paid $800 for 2 of themWhat would that add to the cost, $100?
The garage built are easy to duplicate. A sturdy frame and common components and you save several thousand. If you're fabricator it would be easy to copy their design and components.Because I'm a welder fabricator. I usually modify anything I own anyways. Because truckmounts are incredibly simple machines that are only complicated to most carpet cleaners because they are mechanically challenged. I would build a similar machine myself if I had more time.
Not saying I'm sold on it. I usually buy slightly used because I dont need a warranty. For me to use my warranty that I would pay thousands for I'd have to drive 2 hrs just to get to the shop.
I'm not opposed to bigger name brand used machines, but from what I've seen I'll check out the TCS and reliabilt machines.
Will reliabuilt develop a HX option?
in hot climates I think water cooled is a must but moderate climates air cooled motors do just fine.Most slide ins are at the side door for air flow.The units Les had the engine behind the driver seat and seem to work fine, I was told the the air fins on the motor are different for our use . For lawn mowers they move and are out doors for air flow . But they both work as needed. And water cooled is even better. jz.
Sounds like there is a huge market for repairs there.
Drag queens have flair. Tms are for work. Prefer to keep the two separated. Console only I believe, retail is 13k.What's that unit run and how much for for a bit of flair?
Here's his FB page. No yelp reviews and his about us webpage is a little vague.Anyone out there purchase a Reliabuilt Truck mount? Can you review it for us? Thank you.
My protege!Potty mouth
