These damn things..
I give up..
I've taken all of mine out. Installed 100 mesh before the valve. Yes, the wand drips a bit but it's manageable.
jack zerkie
I use the white magic set up with the wand using a female and the supply a male with a shut off. Just clear the wand and disc connect the supply line and no dripping. Yea not a lot of fun but less water on all the tile floors. jz.
I still get dripping after I do that. Does that mean the trigger is wore out?
You have to clear the water from the wand after the line is removed into the carpet give it a little time then you can move to the next room.
When I am done with a room and need to cross a hard surface floor to get to the next one, I turn off my valve and do a few dry passes. The vibration shakes out the solution still in your manifold and line.
jack zerkie
My water runs about 210- 240 hard not to have leaking due to the heat just keep changing things and maybe no leaks for a short time ?
I bring in drop sheets but can't always cover everything.
paint_template-1
paint_template-1
note the 4 x 24 ft
covers an entire flight of stairs
machine washable in the mega size laundromat machine
I've always considered drops as cheap insurance
and custys appreciate it
Used 100% of the time in res, and empties that weren't ratholes
don't be a
kUVNn31x3SNhpt8kyam2FE-G5RBCu2Gk0h2OvFZTJ1g3qT3z5EGhmg9VoXIes5KFuygS=s180
lta
Chris A
If I can't cover all hard floors I'll at least do the entrance to the house and entrance to the room being worked on. I don't cover wood steps their deadly enough as it is. I always go through and wipe drips when done
