Sierra Clean Care
- Jun 20, 2016
- 6,560
- Name
- Jeff T
Holy shit
Just DONT spray the hose with prespray.... and clean it EVERYTIME you Coil it back up.... wet rag....Maybe you got the Wednesday hose. My continentals were a Monday or Friday hose
Have your hoses ever bled that pretty blue line on the wet sprayed carpet?
Oh hell, I'm just going to go with Continental again. I’ve been using it for 6 years now and its been groovy.
Goodyear, i replace every 12 months on the dot.
Who knows if it can be recycled.
Or using door wedges to hold the door open.Not Pulling on it when there is a couple loops has become my challenge. Even when wrapping it up.
The door issue is easily solved by laying out vacuum hose first.
One more thing to leave behind. Yes I have.Or using door wedges to hold the door open.
The vacuum hose by itself won't stop the pressure hose from getting pinched sometimes.The door issue is easily solved by laying out vacuum hose first.
If you can handle a wife, you can handle Parflex
The real question is, does your wife handle your hose?Now I know Paula does not read these boards.
Probably has much better things to do.
Yeah you have to leave a lot of slack so it doesn't pull towards the jam.The vacuum hose by itself won't stop the pressure hose from getting pinched sometimes.
I prefer to prespray before bringing in the vac hose, so I drop a towel in the hinge side before rolling out solution lines.
Is that you Forrest?I like those bungees to hook to the side doors of my van to the wheels when it's windy.
And that's all I got to say about that.
A 8’ 2 by 4 will produce about 25-30 door wedges.... and they are about 5$ a board... If a guy leaves a few behind, who gives a shyte....One more thing to leave behind. Yes I have.
And Jimmy for the win.... can’t have too many bungees.... they’ve got to have plastic ends though... don’t want to scratch the paint, or Mrs Pilfingtons banister....I like those bungees to hook to the side doors of my van to the wheels when it's windy.
I use scrap wood I make them for my wife she uses them for her weekly Hallway cleaning.A 8’ 2 by 4 will produce about 25-30 door wedges.... and they are about 5$ a board... If a guy leaves a few behind, who gives a shyte....
