Refill before lunch for sure.
65 is too small. You should see if they have a 100 available.
Yep knew it. You're eating mold. What a cheap date!Black Fungus and garlic.
Next time you have a customer with black mold, just tell them to sprinkle with garlic and get a spoonBlack Fungus and garlic.
We see that. Takes up too much precious space for its tiny capacity.Guys y’all can’t see that it is a custom freshy tank ( or one Thaat was designed for over the wheel well design.) that he has set across the van?
It has a place to store some blocks or something.
You saw the dimensions I posted.Lee if you put a 100 gallon it would easily take up twice that space.
He won’t have winters to deal with, or any of the simple problems that booking up and refilling bring in let parts of the world.
I'd mount it in empty space above the machine/ waste tank, leaving floor open. ...and no transfer pump.
I have 2x100 gallon waste tanks and a 125 gallon fresh tank. No room for a transfer pump. 38" x 96" open center floor in the back for buffers and stuff. Lots of shelves. Will do pix.View attachment 79592
Still dying to know how you plan on suspending 900 pounds from that thin roof..
Ill bet Lee a gallin of Cimex paint that i have more floor space in this set up than his..
That cut out where the Chem jugs are is probably about 35 gallons.View attachment 79592
Cimex is painted, special stuff to stick to plastic. I'll put it together the night before a big school project in June.
I'd draw a picture of how to mount your water tank, but you've made up your mind it won't work.
