Shower cleaning need help!
Swani
@Mikey P what's that grout sealer you used on a post awhile back? I'm thinking of using bar keepers friend followed by alkaline. Any other suggestions? All the edges and corners are siliconed and that's where the mold is growing.
Do you mean Super Grout Additive ?looks like a perfect fix for those open gaps
P
Paul
Super Grout Additive is the good one to go for. Easy fix and help those grout lines sustain for long. Here some easy tips to get ahead with grout cleaning afterwards, follow steamprony.com/four-helpful-tips-to-clean-the-grout-between-tiles
Reactions: Living The Dream
I’m getting calls for it.
I’m turning them down because mthe impression you’ve given me is it’s 8 hours with a razor blade.
Yes, but I don’t recommend you get one. The pressure washing tools you have will do very well and are useable in conjunction with your truckmount.
How? Nothing stays on the walls long enough to remove the mold and the grout never whitens up like the floor.
Well, I’ve had success with bleach and detergent, Barkeeper’s friend for lime deposits and Venom peroxibright. There are liquid oven cleaners which are not lye based and cut crud really well.
In general, I’d suggest spritzing the wall from down to up, then lathering it up with a soft brush. Rinse with your gekko or whatever you have, then if there are any discolored spots, spritz bleach to lighten them.
I just can’t see laying out a few thousand for vapor steam equipment when you already have heat and pressure.
I would be glad to loan you mine if you want to mess with one, though.
Acp
Bjorn Marshall
The commercial vapor steam machines are only worth it if you get the really expensive ones that go above 300-330f
most of the moderately priced ones only do about 230/240 degrees and low pressure so not really any better than a lot of truckmounts
Latest Auctions
