Goomer
- Feb 9, 2009
- 3,398
- Name
- Frank Mendo
The #117500 vacs were good at the time, with 530 AirWatts.
The brand new AirWatt vacs are 720 AirWatts . . .
36% more air power @ less current
Do you sell these vacs direct?
They were both 1/3 HP motors. The new one is more reliable.
Ok so the mosquito extractor is 270...CFM and 135..lift
the LTD5 is 230...CFM and 144...Lift
Thats only 40 more CFM not a significant difference at all over the LTD5
difference of 144 lift on LTD5 and 135 on the mosquito not a significant difference either i'd call it a wash
Think i may just have to hold out till a machine with the 8.4's mounted directly to the bottom of the waste tank each having their own
stack pipe (if thats what you call them) is available then it would be more worth it to get something new
These are definitely high CFM vac motors (from specs=166 CFM open; & 176" of lift-
measured)
If someone was interested in a new 1005DX with that new 400 psi 1/3hp motor instead of the big heavy 1/2 hp Marathon, would you be able to accommodate the request and cobble one out?
Sure, we have used both of these configurations successfully.
The 1/2 HP motor has a big advantage in being able to do Grout & Tile work
with a Turbo Hybrid @ 1.5 GPM.
We think Hi-Airwatt extractors able to do carpet or Tile/Grout @ 500 to 700 spraying are the machine of the future.
Kevin, you should just hold out until Mytee introduces an adapter for the new 6.6's.
Total CFM in parallel would be 332, and 176" lift.
It would be an animal of a machine.
I am not sure of calculating lift in series, but in series, CFM would remain 166, with ? lift.
Well if the CFM would be 332 and lift 176 i'd agree that would be awesome , but according to larry on that mosquito machine with the duel 6.6 mtrs duel stack parallel the CFM is 270 and lift 135 how did you come up with your numbers
However, the dual 6.6" vacs mounted directly to the recovery tank . . .
are not as powerful as the new 700 AirWatt series Vacs on the Breeze machine.
Skeeter is not using the same 6.6"s that Larry has formulated I believe.
Larry, can you clarify this........
As far as I understand it, when calculating the total cfm and lift of two vacs in parallel, the total cfm of both vacs is added to each other, and the lift total is equal to the value of one vac.
When in series, the cfm total of the two vacs is equal to the cfm of one individual vac, and not a cumulative total as in parallel.
So when in series, how is total lift calculated?
In discussions with the two major vac motor manufacturers, the only accurate method is actual lab testing.
With older vac motors,
a rule of thumb was series vacs added about 60% lift, and parallel added about 5-10% CFM.
measured)
Total lift with 2 of these vacs is 170" .
I'm guessing they are 110" of lift each.
So the Series spec is ~ 180 CFM with 170" of lift
vs
Parallel 340 CFM with 110" of lift.
The key is that the lift and CFM drop less with these AirWatt vacs than other 6.6" & 5.7" vac arrangements I have tested.
Most of the customers testing the new Breeze state that it feels like a entry-level TM.
I do have a manifold that will series mount 2 of the new vacs with no connecting hose:
Pure BS!
They have never used an entry level TM or they wouldn't clean with a portable.![]()
Five gallons of gas in the solution tank and a match. Hopefully, your 16 inch pos castex wand is nearby as well.I have a old castex walkbehind with a single 3 stage and I'd like to at least toy with it and upgrade the vac motor. What do you recommend and how much?
Can't you hook up a water hose? If not, I'd invest in a setup where you couldHere's a new idea to include on portables: a tiny float in the fresh water tank so it shuts off instead of pumping itself dry. The 2lbs of float would be well worth it. I hate it when I run it out of water. It's hard on the pump and wastes time re priming.
IF it were true Stephen there are still so many factors that make a portable a poor comparison to a TM, even an entry level one.I actually agree with this, but it feels comforting to make excuses. So nyah.
