Project: The Making of a Rug Plant
T Monahan
Ann Arbor, MI
Tom Monahan
Tom,
Could you explain the layout with for the rug plant for flow of cleaning rugs, with the locations of each piece of equipment you are using? Also interested in where storage for clean/done and dirty rugs is with this lay out? Do you have this detailed on graph paper? I did see the sketch in the first few posts, just looking for more detail and understanding of space and sqft needed operate properly. Also what is the actual sqft used for the rug plant, minus all the office, show room, training area's? Thanks, really liking this thread!
T Monahan
Ann Arbor, MI
Tom Monahan
Nice set up Tom. I'm just wondering if you vent the area with the tumble duster or is it not necessary?
I am waiting on the delivery of my Dust Collector. It will draw air by ductwork from inside the room They were out of stock when I ordered it. Here is a picture of it:
T Monahan
Ann Arbor, MI
Tom Monahan
I was reminded to clean out the gutters after the high winds weaken them a bit. A contractor secured them better and subsequently cleaned them out today too:
rick imby
Montana
Rick
Excuse my ignorance---This is the unit that pulls the air from outside, heats it and then heats your drying room? With the Exhaust coming out of the Top of the room---grin--?
Are you going to harvest any of the exhaust heat? Maybe to preheat your hot water?
Reactions: T Monahan
Northwest Arkansas
Man, apparently I need to start becoming knowledgeable on oriental rugs so I may be able to do this one day.
I clean some wool rugs on site but honestly rugs kinda scare me.
Where's a good place for a rug newb to get started learning and training?
T Monahan
Ann Arbor, MI
Tom Monahan
The moist or humid air is evacuated outside at the same cfm it enters the drying chamber. It runs on and off on a cycle. No plan was eveer intended for savaging the humid air. Think like a clothes dryer in your home. Same principle. It is more economical than dehumidifying.
T Monahan
Ann Arbor, MI
Tom Monahan
Aaron Groseclose or Ruth Travis instruct an IICRC RCT course.
rick imby
Montana
Rick
My thought is build a water preheater heat exchanger like a TM.
Wrap 200 feet of copper Tubing around an 8 inch pipe to make a coil. Suspend the coil inside a 14" inside diameter Sewer pipe. The stick you suspend the coil on could have notches to keep the coils apart.
The air intake to this would be right next to your ceiling. Slope it down so the condensed water goes to one end to drain. You can run the drain into one of your trenches.
Run the water through the copper coil before it goes to your water heater.
Since this is all inside you don't need to worry about freezing.
There are no issues with overheating the water or high pressure like in a TM so this is really low tech, low risk.
I would bet this would have a very fast payoff.
rick imby
Montana
Rick
With your fabrication skills I'm sure it would be much nicer than what is in my head---
The one I built in my head has about $300 in materials. The payback would be quick...
cleanking
Indianapolis, IN
Jordan King
Years of Experience
19
Role
Business Owner
Amazingly original name "Area Rug Cleaning Company" Did you have a contest to name it?
Come on @T Monahan
It's actually super smart. We've named our business similarly and it drastically helps with SEO. Customers don't care about a snazzy name, they want you to know what you're doing with their rugs.
T Monahan
Ann Arbor, MI
Tom Monahan
The weather this Saturday got above 60 degrees. Therefore time to paint exterior doors.
The Max Scherzer look to start things out:
