Nate The Great
- Mar 29, 2008
- 9,738
- Name
- Nate W.
Hey who put "The thread Snatcher" on me?
Fookers!
Better than snatch snatcher......
Fookers!
?Is the manifold threaded for the bolt or is there a nut in the inlet?
Kind of what I'm wondering?Another perfectly good thread screwed.
when are they going to go on a road trip like this one.have you tried a well tuned Devpro?
Glide update.
PMF has discontinued their two piece glides due to very high manufacturing costs.
the Mach 12 and 15 will have a press fit round glides. Which according to my pal there, will not leak or shift side to side.
Derek (D Luke) is getting one the same time as Pemberton.
If he passes on it, we will send it to Canadian Russ next..
Noooooooooo...........Hopefully they won't screw up a good wand.Glide update.
Glide update.
no, one went out with the two piece flat glide, not sure about the one headed to Pemberton
Dang ... Jim sure is pissy today.
Will quit screwing around with it and get out to us where we can decide if it's any count.
Are the jets so close to the carpet that streaking occurs?
Does the barrel cause the two inside jets to clean unevenly in the center?
How low does the pressure have to go before it will dry a carpet in 3 hours or under?
Does this wand have a "totally adjustable manifold"?Have you looked at any pictures of the totally adjustable manifold? Neither concern should be an issue.
