Rust removal
on tile what's the best product. Currently I use star clean and a zep acid with a scrubber by hand. Works but very slow. Today we had a lot of rust and I spent close to 1/2 hr removing it. Must be a faster product.
Thanks. Gene
Years ago I used to use automotive rubbing compound. Same thing on glossy tile. Gotta go easy. What works on gloss
Gene
cameron demille
Alpha RSR 2000 will get it off. It turns it purple first, then you have to clean the purple. Not a big deal.
Willy P
Willy P
BE absolutely sure to use a respirator and long gloves. You haven't experienced pain until hydrofluoric acid starts eating into your flesh. How do I know this? I got it on my fingers once. 2 fingernails removed, both fingers surgically cut to the bone and calcium injections to neutralize the acid and the incisions left open to drain.Extremely painful. The only thing that will contain hydrofluoric acid is plastic. I now have very limited feeling in those 2 fingers. There's far safer ways than that.
cameron demille
That burn is from 70% HF, nowhere remotely close to the concentration you can buy it in. Yes its dangerous, but not as dangerous as what caused those burns
You should always be careful when handling chemicals.
jcooper said: ↑
http://www.walmart.com/ip/15716648?...43378192&wl4=&wl5=pla&wl6=78303990512&veh=sem
If it's rust this works every time. Carpet, tile, whatever...
Dam Willy! Thanks...
Willy P
Willy P
My burns came from "carpet cleaner strength" hf. It's very dangerous in any concentration . Can you smell it? Then you're absorbing it. There's safer products to reach the same goal.
cameron demille
Yes, you can get burns, I was talking specifically about the pictures in the two links posted. You won't get that from anything off the shelf
With that being said, HF ain't nothin to F with
Reactions: Mike Pailliotet
