Tile wand
The same head is available in a hand tool (w/ten foot hide A hose) from PMF.
We love it for steps, counters, walls, showers, around toilets etc.
I can't see having the hand tool AND that wand option both. We prefer a hard floor wand with a 14" head for corners and under things the Spinner wont get to
If you'd apply the right products you wouldn't need to do all that work.
Gene
I thought the product mikey was using was pretty good.
What would you recommend gene?
realclean
Jesse Lowe
Oh and I do not want to bend over in order to get into the tight spots unless I have to.
Looks like mostly soap scum with some mold and minerals in it. Easy off oven cleaner will remove it no problem. Rarely use an acid to clean tile. I also use a product similar to clr but the name is eluding me right now. I have some zep on board but rarely use it because it's so strong.
Gene
