How would you handle this difficult but common situation?
The door is just to the left so no way to attack it from that angle..
So do you..
Hose cuff it?
Go get the Uph Tool?
Unscrew the door stop?
Spray spotter and wipe with a towel?
"Sorry Mam, that there is permanent.."
Slam your wand into it dead on and HOPE it's the spring type?
Open the door and hope they don't notice?
Apply Dinge Away?
Nothing a good squirt of fresh 40 can't handle...
another difficult situation
How to re letter both trucks....
Brad from Turbo Force is working on something...may need to get Chavez involved as well..
KevinL
East Peoria Illinois
Kevin Leach
I would try the hose with a rag swipe and if that didn't work, the stop comes off. Hey Waldo, How many of your top 25 would do that?
Erik
Michigan
Erik
So do you..
Hose cuff it?
Apply Dinge Away?
The first thing I would do is clean the rest of the carpet (or is that clean?) I would use a good spotter and a damp rag.
Reactions: truckmount girl
Erik
Michigan
Erik
Fred, how did you delete your post or is that private information?
Mike Draper
Your a hack if you don't have one of these. Great for spots like the one you are trying to Tackle. Awesome for wax right on the edge. Call Olsen and have him send you one.
Charlie Lyman
Meridian, ID
Charlie Lyman
1):You need to be a lot shorter with a short persons wand and you can get that angle.
2): call the girl that did my logo. She could design a sweet wrap for you.
idreadnought
Oroville, ca
Richard
I guess I am a hack.......I would mist it and hose cuff it. If it still didn't clean up I would break out the upholstery tool.
Brian H
Detroit Michigan area
Brian H
I don't consider you a hack because I have never seen the work that you produce. One thing I would recommend though would be to have clean equipment when you go into a job. Especially if you are going to take a picture of it and post in THIS board. :)
Arizona
I guess the bigger question should be.........what idiot came up with putting door stops on the base boards......??
all of mine are on the backs of the doors where they belong.....they are never in the way...when we vacuum we can get up against the walls with no problems.......
Internal jet crevice tool... We've had some with the magnetic type too, leaving like 2" away from the wall.. Most of the type it comes clean with just vacuuming..
I've never in my life of living in Hawaii seen any floor vents...
Uph. tool or spray and wipe!
Definitely not pulling out my old millers stair tool! that thing would blow a whole in the carpet with its # 8 jet.
