Blower
glenboy
MACOMB MI
GLEN
Went to tighten my belts and pulled on them first and they would not move.cycled the machine and oiled oiler hole.removed belts and blower turns but it drags rather spin free.no lash in bearings.its a roots 45 with a lot of hours on it.wondering if anyone has had this problem.or should I be ordering a new 45
Dallas, Texas USA
Glenn;
First thing to do is to clean the interior of the blower.
We use our Dynachem POG to clean any residue from the blower interior.
After spraying the POG throughout the interior,
I would use a prespray to do a final flush.
Rinse with hot water and check if it turns freely.
If it still is binding, I would replace the driven shaft bearing and seal.
Larry
Benton KY USA
Depending on the nature of the "drag", I'd agree that there is trash in it. When enough gets into the blower cavity so that "grit" gets between the endplates and rotors it won't spin free.
Should be NO metal to metal contact inside the blower, and no drag from bearings either. Just slight inertia to start its motion.
glenboy
MACOMB MI
GLEN
I tried it all,and it spins freely.should have done this years ago.THANK YOU ALL :rockon:ABOUT A CUP OF pog AND A HALF GALLON OF BOILING WATER.FIRST GRAY THEN BROWN THEN GRAY AND CLEAR. SHE SPINS FREE AS CAN BE
