Mike Draper
- Jan 13, 2008
- 4,402
In other words, just buy a prochem ergo ti wand and be done with it. It's been tried and proven. No ongoing problem after problem with the design.
You have been talking about your revolutionary wand design for a couple of years...I even gave the TI wand I won on the auction back as a chance for Jimbo to buy it because you kept insisting on your new design coming out and for me to wait...because its gona be better and more ergo than the TI and Bentley.
So what's up?? I had the freaking TI Ergo for 900 bucks but gave up on it based on your info that you pm-ed.
I guess I should have just bought the TI Ergo.....
Probably just letting him know I was doing a lot of testing on the so called Ergo wands and I found out that they are not really ergo at all. They can cause chronic finger and joint problem and the I was working ona big improvement that improved my trigger finger and other problems I was having. I think it would help out a lot of the guys. For instance I bought a gun valve wand and my thumb joint became numb and wouldn't bend for several months. I couldn't see an other cleaner go through that.so you are abusing the PM system to promote a product you aren't even selling yet?
hmmmm....
Has anybody tested the S S wand with a truckmount that has some real power? Wonder how that Y does down on the head of the wandWell if you are looking for ergo, then go for an old Stanley Steemer 6 jet wand.
Take care,
Lisa
Tom. The ergo ti wand is the Stanley steemer wand. Stanley had exclusive rights to it. Then released the rights about 4 years ago which opened it up to the free market.
I am 62 years old And have been using my Bentley wand since 2008 and no problems whatsoever in my hands. I would however like to try the lighter carbon fiber wand. I also like food too much!!!
The only complaint I have about my 16 inch CASTEX wand is the head is heavy.
John Olson" data-source="post: 4222682" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Serious?
I was talking to ZeeYeah, I was paying attention to how I hold my wand today..I switch up my grip from when I trigger to when I do dry passes, for dry passes I actually push on the end of the wand with the vac hose, for triggering I move my hands up and hit the trigger with one finger . Keeping your hand in the position the ergo wand makes you is alot of pressure on the same points in your hand. My helper hated the ergo also, he would always grab the regular TI..
learn to wand from both sides of the wand ..if you don't, DO IT NOW.
