Completed Saiger's Sauce "It's all about the OXY" auction!
Completed Auction
Village Idiot
Up for auction:
  • Two 6.5 Tubs of Saiger's Code Red Powdered Pre-spray with Enzyme and Oxy
  • Two One Gallon jugs of Saiger's 2X Double Strength OXY Encapsulation Cleaner (The Code Red of Encaps)
  • One 4 x 1 Gallon Case of Saigers OdorOxy for Stain and Odor control and Removal
SAIGER’S CODE RED POWDERED PRE-SPRAY
When you’ve got a carpet cleaning emergency— call a CODE RED!
Saiger’s Sauce Code Red features the same great formula of original Saiger’s Sauce 1 plus an added oxidizer and enzyme to power through the toughest, greasiest, grimiest soils you can find.
Stable Oxy and Enzyme Combination
Code Red relies on a high-performing oxidizer plus a fast-acting protein enzyme to digest oily deposits and organic soils. It breaks down thick, sticky binders that hold onto dirt and soiling, emulsifying them for easy rinsing.
With other enzyme-based formulations, the addition of an oxidizer and heat will destroy the enzymes and render the product ineffective. But Code Red’s enzyme is not sensitive to heat or harmed by oxy, allowing you to get the power of both agents in a single formula.
Code Red was designed for cold water efficiency and effectiveness, so it's great for smaller truck mounts and portables. (Though it performs well and works even faster with heat!)
Note: Once mixed, Code Red doesn't have as long of a shelf life as other Saiger's Sauce products. We recommend using up your mixed batch the same day for best results.
Saiger’s Sauce OXY Encap 2X Double Strength Encapsulant Cleaner
“The Code Red of Encap Cleaners” is a concentrated highly effective low pH cleaner, with the power of Peroxide and our revolutionary encapsulating polymers. The peroxide helps with organic stain removal, odor removal, and helps to make those fibers colors “pop” with brilliance! The Encapsulant captures the soils, rounding off the soils jagged edges, and coat the carpet fibers for easier soil removal. This highly effective encapsulant also helps to coat the fibers to prevent re-soiling and wicking of stains. The Polymer will dry to a crystal for continued easy soil removal. This is a very Low Odor product with a very light fresh scent during cleaning.
This product is effective with Color Fast wool (test for color fastness) and synthetic fibers.​
For use with Bonnet, Rotary OP, Counter Rotating Brush, Cimex, 175, hand scrubbing or as a prespray for Hot Water Extraction. Can be used with a shower feed or as a pre-spray. (Helpful Tip: We recommend rinsing out your shower feed systems after use to prevent encap from plugging up the system) This product works very well when using absorbent pads for immediate removal of encapsulated soils. pH: 4-5 pH
Saiger’s OdorOxy Urine Odor & Stain Destroyer
  • True odor elimination chemistry
  • Can be sprayed and walk away to continue working on stain and odor
  • Eliminates stains and odors
  • Powerful oxidizers
  • pH: 4-5
  • For use on carpet, upholstery and other fabrics
  • Effective on pet stains, blood, coffee and tannin stains, vomit and other organic stains
  • Pleasant fresh scent
  • Available in 4x1 gallons
Odor Elimination with the Power of Peroxide and a True Odor Destroyer!​
ODOR OXY is a unique high powered Peroxide formula with a true Odor Destroyer! Not a masking agent, but a product meant to go after the urine and odor causing organic stains! With the power of Peroxide and our unique Odor Destroyer. Designed for those cleaners who do not have the time for enzyme activation, and need quick fast results!
Odor & Stain elimination oxidizers that will remove organic stains including pet urine, blood, coffee, vomit, and more. A unique formula to eliminate unpleasant stains and odors in carpet, upholstery and other fabrics. Avoid using on Wool and Silk materials, and be cautious with natural fibers.
Total Auction Retail Value $320.39
Free Shipping to lower 48
Starting bid $225
Minimum bid increment $5
Auction ends Wednesday May 8th at 9PM EST/6PM PST
