a bathroom floor that evenly dirty is from mopping. good for you. with a drain in the floor they could keep it clean if they knew how.
gene
gene
danielc said:Kevin P said:danielc said:And someday you will have to strip that floor finish off.
It's not so hard to strip off. I have done it numerous times.
Daniel,
For starters stone breathes,but if you want a high gloss shine that will become a little less porous you can hone and polish it.I dont even like the thought of a man made with a finish on it.
danielc said:I would have sealed that floor and with their permission put several coats for floor finish down. That really helps protect the floor and makes cleaning easier.
danielc said:Yes Doug it peels right off if you have enough pressure. 1000 psi just doesn't do the job. You need closer to 2k psi and the wax will come right up. Just be prepared to change your filter a bunch of times. And why would you need to get the wax off except maybe once every 10 years. The floor can be cleaned and re-coated. Good stripper, the right brush, and the right pressure will take it right off. But yes I agree with you that on that particular floor I would advise against finish. I didn't see the pic real good on my phone.
