ACE
This kitchen tile did not clean up as well as I hoped. Part of it looks great and part of it looks really bad. I cleaned with Procyon and Chemtex’s Supreme (PH 12) using 12” Spinner at 700-900 PSI. I’m thinking of giving it another go using a strong acid in some areas and citris solvent to take up the grease in other areas. The thing I’m really worried about is area where the grout is a gray color and a bit higher. Is this a problem with the original installation? It looks like there is some cement between the tile and the installer just put a very thin layer of grout over it or someone did allot of repair work with readymix. I seen this before on other jobs, but never this bad.
