Bayco vs Kunkle?
CleanLiving
Why should I have one of these new valves and which one is the best choice?
You can't use one on your Bane.
In the 2" and 3" catagory, I favor the Bayco, just more accurate from the factory, less returned items (actually 0 so far), the kunkles vary more.
I'm pushing these with our distributors more and more.
For 2.5" I still offer the Kunkle (mostly 56 blowers), and luckily this size has been fairly reliable, probably because we don't order them in a stock setting, so they have to set them individually.
They make a #3 suck like a #4 blower.
CleanLiving
Thank-you,
If you could for me, go over the 2" and 2.5" wand and hose improved vacuum stuff I keep hearing about on this board. I'm certainly appreciative for your advice but surprised I hve not heard of this having been through so many certification programs.
Also, what exactly is and what's the benefit if a whip hose.
Cheers
Greenie, Tom mentioned on the SW room, his PM runs smoother because of a "controled leak"
I thought they cycled by opening at X hg and then then closed.
What's the typical hg drop between cylcling open, and then closing
