405 heat exchanger
jmo
Tucson, Az
Jeremy
Does anyone know where to get a heat exchanger for a 405? Mine is plugged up.
Village Idiot
ebay?
Blue Baron makes (?) a direct replacement exhaust exchanger
not sure if there are any updated options
Benton KY USA
Just bypass it by adding a 3/8 compression nipple between the hoses going into each end of the "bad" exchanger....(which is nearly indestructible)
Reactions: jmo
Georgia
Or you could use this heat exchanger. It’s originally one from my blueline TM2 that used engine coolant. But it is stainless steel fin tubed inside and if the holes were cut big enough for the blower’s exhaust, it’d work just fine.
It might fit if you lay it on it’s side in the port where your round one goes
The reason I pulled it out is because it leaked antifreeze around the stainless steel tubes. It’d be a perfect exhaust heat exchanger. If you have some shop skills and want it, just pay shipping.
