MB Auctions
- Joined
- Sep 15, 2014
- Messages
- 92
Up for grabs is a new EDIC TWO SPEED (180/320) Floor Machine in your choice of 17' or 20'
Free pad driver and FREE shipping (L48)
$1100 to $1200 value
Fantastic for HWE Prescrubbing, Commercial Carpet Shampooing/Encapsulation, Tile and Grout, VCT, Stone, Wood, Concrete and more!!
Get more bang for your buck with one machine that does the work of two! Strip, scrub, spray-buff, polish, shampoo, bonnet clean... you name it, this machine does it all! Designed for professional floor care maintenance, the dual speed floor machines from EDIC are equipped with long-wearing steel triple planetary gearboxes, providing heavy duty yet quiet operation. Safety comes first with the exclusive 'lockout' lever that allows the motor to be activated while keeping both hands on the handle grips. Use the lower speed to scrub and strip then just flip the switch to high speed and polish floors to a glossy luster. Operation is smooth and easy in even the toughest commercial settings.
Warranty : 3 years parts, lifetime on stainless steel apron.
MADE IN THE USA!
Diameter17'
Motor1.5 HP / 66 frame
Gear BoxSteel triple planetary
Power Cord50' yellow
Cord Strain ReliefHeavy-duty steel with spring guard
Pad DriverOptional
Brush CoverStainless steel
Handle GripsSoft, anti-fatigue
HandleChrome-plated steel
Wheels5'
BumperNon-marking PVC
Operation ControlAll metal , dual on-off
Weight86 lbs/ 112lbs (20')
Shipping Weight106 lbs.
Shipping Dimensions48'H x 26.5'L x 23'W
Electrical Draw14.4 amps
2 Speed EDIC 175 Floor Machine
MADE IN THE USA!
- All-metal construction with stainless steel brush cover, heavy duty chrome-plated steel handle and 66 frame motor assure durability.
- All steel triple planetary gearbox provides heavy duty yet quiet operation.
- Dual trigger negative pressure switch allows operator to run with either hand.
- Safe two-handed start-up with exclusive 'lockout lever'.
- Cool running 1.5 HP high efficiency motor.
- 50' power cord.
- Non-marking PVC bumper prevents marks on walls and furniture.
Diameter17'
Pad DriverOptional
Wheels5'
