Peroxide products
Montana
Swani
Two days ago I mixed up some Encapuclean 02 and didn't use it all and today I have another commercial encapsulation job. Would you guys use the previously mixed product or mix new. I know it's only a couple dollars worth of product but it is Sunday and I'm almost out of Encapuclean O2 and if the answer is that the peroxide is no longer active in the premixed stuff could you add something like Volume 40? As always thanks in advance for your suggestions.
O2 won't work with other scampoos. They will NOT crystallize .
That encapucleanO2 is garbage...................smells rotten and is a FILM FORMER.
In my opinion
Jimmy, you got an old batch. I've used Encapuclean o2 often with no problem. Don't keep it in a hot truck. Use it up when you open a bottle. It will go bad and start smelling like Willy in the morning.
Reactions: Living The Dream
Montana
Swani
I tested it like Matt suggested and there wasn't much fizzle. So I blended it off with a fresh batch and it worked great. It always amazes me how much nicer the carpets always look the next day. Thank you everyone for your input.
