Cobb’s impregnator sealer
Josh Almanza
Houston, Tx.
Josh Almanza
Can I apply Cobb’s sealer to tile and grout right after I’ve cleaned it(after I’ve set up air movers to dry quickly)? Or do I have to do it another day, after the t&g is completely dry? Thanks
Redding
I put down air movers and get it dry as possible before applying the Seal-A-Cobb. I've had really good results with it. It hasn't mattered if the grout is still a little darker because of moisture. Just do what you can to get it as dry as possible before applying.
Dallas, Texas USA
The surface should have no drops of water visible.
Usually a small fan will have the floor dry enough in 15-25 minutes.
We formulate to save you time.
Our newest Fluorochemical Sealer w/UV absorber has passed stringent Zenon light testing with the highest rating (5 on 1-5 scale). It is used to prevent UV fading of dyes & for outdoor floor exposure in full sunlight.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=78&products_id=5150
Larry, how safe is the ultra seal on cheap metal? I have some red outdoor furniture I'd like to try it on.
clean image
Orlando
Carl Maddock
Larry, what does this mean in real life?
If I spray it on a new exterior travertine paver deck , it won’t lose its color? (Fade)
( which typically will start to happen in 6 mo. In FL)
And how often would need to be reapplied?
Dallas, Texas USA
I don't know the exact answer.
The Xenon UV testing we got back showed an improvement from a "2" rating to a "5" rating.
That would indicate 250% longer life in direct sun.
Our UV absorber is NOT water soluble,
so the Florida rain would not wash it out of the stone.
Steve; Is the furniture painted steel? The UV absorber is used in paint to prevent fading.
