Buying and getting chems shipped that are Freeze thaw Sensitive
Mardie
London Ontario,Canada
Mardie VanBree
Do you ask if your chems are freeze thaw sensitive ? Does your supplier warn you about chems that are freeze thaw sensitive ? Do the chem manufacturers put on proper labeling or notify suppliers about freeze thaw sensitive chems or do they care. As a precaution when it is cold I will order my chems on a Mon. so they do not sit in a cold truck over the weekend and get them shipped overnight just in case. For the most part I do not trust that proper warnings are in place.
encapman
St Petersburg, FL
Rick Gelinas
This is a question that we answer all the time throughout the winter at Excellent Supply.
And the answer is... No need to worry, Releasit products are freeze/thaw stable.
It is a valid question though, because products that are shipped at this time of year will likely become a popsicle at some point during the journey.
Reactions: Art Kelley
Dallas, Texas USA
Mardie;
Very good question for this cold weather snap.
Shipping on Monday is a good idea, since it will usually be delivered by Friday from our Central U.S. location.
One product to be careful with is water-based fluorochemicals.
Most of the best performance products WILL NOT withstand a hard freeze (down to 20 degrees or so).
Some presprays are vulnerable as well.
If any products freeze, warm them up slowly and then shake them up well.
If they separate or have any precipitate then they are most likely ruined.
Also, be careful with equipment. Some need antifreeze for shipping in cold weather.
Larry
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
The manufacturers know and repeatedly tell the distributors. Hopefully this information gets passed along to the buyer when needed.
In the Bridgepoint line, the wood floor finishes are the most sensitive to freezing. Bridgepoint's Maxim is freeze / thaw stable and will not be a problem. However as Larry indicated, many water based products with polymers / fluoroprotectors should not freeze. Be cautious with Scotchgard or Teflon.
Larry also had good information on gradually warming the product. Make sure it is completely thawed and liquid with no ice crystals left before you try to use it.
