I have descaled 4 times. Twice with prochem descaler and twice with Clr. As well as just the heat exchangers with a motorized 12v pump.
I don not have a watersoftner so what is the recharge all about (confused) . I live in the California Bay Areas
I have noticed disconnecting the radiator fan temp goes up. Takes forever. I connect it back when it finally gets to 200 and even took it to 220 so I do not blow the Kubota engine up. I connect fan back it gets cold.
I am stuck and I need some damn heat. Any info would be appreciated .Nothing is going into the tank from the fresh water reief valve unless it s very hot .
New thermostats rebuilt radiator. new cap. Bluewave has 3k in hours .
