Best Grout Brush?
JGneda
East Hartford Connecticut
John Gneda
You should give this grout brush a try.From Butler.It's the best I've ever used,it doesn't show it in the picture but the stiff bristles extend on each end so you can get up to the wall.
Swivel Grout Brush 1 X 8
Swivel Grout Brush 1" X 8"
A1531
$18.00
QTY:
The fibers on this brush are trimmed to a chisel edge to allow the brush to scrub aggresively along grout lines. The stiff black fiber will stand up to tough use. Comes complete with 60" standard threaded handle.
Go back
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
I went and picked up a couple of these and was not impressed with the bristles are no where as stiff as my other grout brush.
The usefulness of a brush is not all about stiffness. Flexible bristles can reach where stiff bristles may not and can dislodge soil with spring-like kinetic energy.
If stiffness is what you are looking for, use a stainless steel wire brush. This will wear away the grout - https://interlinksupply.com/index.php?item_num=AB113
