frank fratto
- Joined
- Jan 27, 2018
- Messages
- 316
- Name
- frank fratto
Red Pulls!You're making it way too hard if you insist on vlming residential, which obviously you are. There's no way red pad can pull the same amount of hair as a crb with renovators. If so, you need different brushes, or a better crb. Hair don't absorb into that pad. The most it might do is being pressed and twisted against the pad, not absorbed. CRBbbb
Microfiber ABSORBED!!!
